Hi
According to specifications fit-PC4 should support Wake-on-Timer and PXE Boot.
BIOS is updated to the latest version: SBCFP4_3.0.0.312_9.3 2014.08.24
However as far as I can see these functions is not available in current BIOS?
Kind Regards,
Kevin Peter Gade
Kevin Peter Gade
Re: Wake-on-Timer and PXE Boot
The BIOS with PXE option will be released until the end of the month.
Wake-on-Timer should be working, it has been tested by our BIOS engineer and will be verified again.
The Wake-on-Timer feature was tested successfully with WakeUp application: http://wakeup.win7dwnld.com/
Before using this feature, it should be enabled in Windows.
Great, thank you!
Kind Regards,
Kevin Peter Gade
Kevin Peter Gade
