only one network interface seen
Find IPC2 news at https://plus.google.com/+Fitpc-by-compulab/
hendryt
Post by hendryt »
I have purchased a FIT PC IPC2, it has 2 network cards and I am wanting to use the device for a firewall, but when I install my firewall it is only seeing 1 network interface even though I have cables plugged into both.
Are you able to advise as to why that is?
Regards
Hendry
Re: only one network interface seen
I can't say much about the firewall application, but system-wise the LAN ports are two completely independent and separate networks.
Please see if both of them are seen by the device manager as two network connections under network adapters, one with Intel I211 and the other with I218 controllers.
If not, please reinstall Ethernet drivers:
http://www.fit-pc.com/wiki/index.php/IPC2:_Software
Return to “General IPC2 questions”
