Is 3440x1440 supported on IPC2?
Find IPC2 news at https://plus.google.com/+Fitpc-by-compulab/
belette
Post by belette »
Everything is on the subject :)
I read the max resolution but I am interested to buy an Ultrawide monitor and the native resolution is 3440x1440 so I would like to double confirm that it is one supported .
Many thanks in advance
belette
Re: Is 3440x1440 supported on IPC2?
We don't have matching display, therefore haven't checked that resolution.
belette
Post by belette »
Many thanks for your reply.
Do you think it is enough to check with the video card reference or something else in the ICP2 could limit my findings?
Having the CPU+chipset model should be enough to find that data, as GPU/Video block and display ports are part of the chip. Other parts in IPC2 have no effect on the supported resolutions.
jander
Post by jander »
I did not know the maximum resolution, but I would love to know this issue to be able to buy a larger screen
Return to “General IPC2 questions”
