Can you run IPC2 off a 12 volt battery?
Find IPC2 news at https://plus.google.com/+Fitpc-by-compulab/
herbertmania
Post by herbertmania »
Is it okay to power IPC2 directly from a 12 volt battery? Or would you run the risk of frying it from too much current?
I would like to connect my IPC2 directly to a 12 volt battery and just wondering if anyone can tell me if this is okay to do. I'm just wondering if it might fry the computer from too much amps.
Re: Can you run IPC2 off a 12 volt battery?
It is OK to run IPC2 from a 12V battery. Since expensive hardware is involved it is recommended to seek professional advice.
Surge protection / voltage regulation is recommended.
Irad Stavi
Forum admin
Return to “General IPC2 questions”
