Is it okay to power IPC2 directly from a 12 volt battery? Or would you run the risk of frying it from too much current?
I would like to connect my IPC2 directly to a 12 volt battery and just wondering if anyone can tell me if this is okay to do. I'm just wondering if it might fry the computer from too much amps.
Can you run IPC2 off a 12 volt battery?
Find IPC2 news at https://plus.google.com/+Fitpc-by-compulab/
Re: Can you run IPC2 off a 12 volt battery?
It is OK to run IPC2 from a 12V battery. Since expensive hardware is involved it is recommended to seek professional advice.
Surge protection / voltage regulation is recommended.
Return to “General IPC2 questions”
