Page 2 of 4
Re: Audio Problem - Intense PC
Posted: Sun Dec 09, 2012 2:58 pm
No, there is no registry patches.
You should see something like this on your playback devices tab
Dou you have other HDMI device for testing purposes?
Posted: Mon Dec 31, 2012 10:56 pm
by JuTs
I have the same problem. No sound on analog output (I can't test with digital). But it's like it has not detected that I pluged the speakers.
- Capture.PNG (32.94 KiB) Viewed 19418 times
Julien
Posted: Tue Jan 01, 2013 11:24 am
Dear Julien
If you want to get an analog audio output, you should apply this patch.
The enclosed patch can be also found in the Intense PC audio driver directory
Posted: Wed Jan 02, 2013 10:11 pm
by JuTs
gabrielh wrote:Dear Julien
Intense-PC_Audio_Patch.zip
That doesn't work.
I also tried with an HDMI device and I get the same result
Julien
Posted: Thu Jan 03, 2013 9:21 am
No, sorry. Windows will enable HDMI sound output once it'll recognize a valid HDMI connected device.
Posted: Fri Jan 04, 2013 9:25 am
by JuTs
Hi
You're probably right for the the HDMI device. It's the first time I try to use it for sound.
I try to re-install my system (I have a backup of the system). So I started from a fresh install. I installed the patch, the drivers but nothing better. It's like the system doesn't detect that I plugged a device.
Julien
Posted: Tue Jan 08, 2013 7:23 am
by JuTs
I tried something else :
I'm using Windows 8. I thought that could be the problem. So I tried to install Windows 7. But still no sound. Il also try to install the last driver from realtek website.
Julien
Posted: Thu Jan 10, 2013 8:07 am
Dear Julien
Intense PC uses Intel's driver for the HDMI connection. Once you connect an appropriate HDMI device, it should be recognized by the OS as a sound device.
Please try a live Linux Mint OS to see if you have an HDMI sound output
Posted: Thu Jan 10, 2013 8:26 am
by JuTs
I'm trying to get analog sound. for HDMI it was just a try to check if it works.
But I will try with Mint
Posted: Fri Jan 11, 2013 10:01 am
by JuTs
With Mint 14 I have analog sound.
Julien
