I'm designing a FACE module and want to use the PCIe lanes on the FACE module connectors.
This picture shows an x8 and x2 link from the CPU to the FACE module and two x1 links from the System Controller Hub to the FACE module.
Which pins on the FACE module connector are connected to the CPU?
Are those the "PEG" lanes on FACE connector #2?
Do I need to do something with the DGPU_* signals on connector #2?
(I will not connect a GPU to the PEG lanes but an FPGA used as frame grabber)
Which of the lanes on FACE connector #1 are the x1 lanes and which ones are the x2 lane?
Or can I assign them like I want?
-- Florian
FACE-Module Design: PCIe and PEG lane configuration
Re: FACE-Module Design: PCIe and PEG lane configuration
Hello Florian
Please refer to this wiki http://www.fit-pc.com/wiki/index.php/FA ... umentation for the detailed information about FACE module custom design
I should have mentioned that I have already looked at those documents and the questions I asked are the things I could not find in the documentation.
By the way, the "Face Module Design Guide" is outdated. There were some additions from Fit-PC 3 to Intense-PC that are not mentioned in the PDF. (Like those PCIe lanes I mentioned or the LVDS port)
So, my questions still stand...
-- Florian
-- Florian
Dear Florian
PCIE_TXP8_EXT
PCIE_TXN8_EXT
PCIE_RXN8_EXT
PCIE_RXP8_EXT
IT'S X1 Line that is coming from chipset
PCIE_TXP7_EXT
PCIE_TXN7_EXT
PCIE_RXN7_EXT
PCIE_RXP7_EXT
PCIE_TXP1_C
PCIE_RXP1_C
PCIE_RXP1_SLOT1
PCIE_TXP1_SLOT1
relevant clock CLK_PCIE_P7, CLK_PCIE_N7
PEG_TXP7
PEG_TXN7
PEG_RXP7
PEG_RXN7
IT'S X2 Line that that is coming from CPU
PEG_RXP8 - PEG_RXP15
IT'S X8 Line that that is coming CPU
PCIE_TXP8_EXT
PCIE_TXN8_EXT
PCIE_RXN8_EXT
PCIE_RXP8_EXT
PCIE_TXP7_EXT
PCIE_TXN7_EXT
PCIE_RXN7_EXT
PCIE_RXP7_EXT
PCIE_TXP1_C
PCIE_RXP1_C
PCIE_RXP1_SLOT1
PCIE_TXP1_SLOT1
PEG_TXP7
PEG_TXN7
PEG_RXP7
PEG_RXN7
Hello Gabriel,
I cannot find those signal names in the "FACE Module Design Guide" or in the schematics that come with the "FACE Module Design Package".
The naming is completely different. (Maybe you gave me names used in internal documentation?)
Here is a screenshot of the pin layout of the connectors in the "FM-XTD reference design":
![Image](http://i.imgur.com/z8AS0.png)
Can you rewrite your answer with these signal names, please?
-- Florian
-- Florian
CPU -> PEG x8 AND PEG x1
CHIPSET -> 3 PCIe x1 (1,7,8)
CPU PEG x8 :
P2 A1-A24,B1-B24 RELEVANT CLOCK P2-B26,B27
PEG_RX/TX0 - PEG_RX/TX7
CPU PEG x1 :
P1-B44,B45 A44,A45 (PCIe 0)
P1-A35,36 B35,36 (PCIe 3)
P1-A38,39 B38,39 (PCIe 2)
P1-A41,42 B41,42 (PCIe 1)
CLOCK : P1- B32,B33
CPU PEG x8 :
CPU PEG x1 :
CLOCK : P1- B32,B33
