Hello guys the sd card slot fit pc 2 is too small. why is that the sd card does not fit into the fit pc 2 slot? I try to keep forcing it.
I also bought a SSD 30gb sata II 2.5", but realised that not many computers take it as it is quite new technology, so therefore will I not get all the speed out if it? What do you think I should do, get a new hard drive that's slower but with more space for the same price or keep this one?
Thank you guys
answers needed
Re: answers needed
It doesn't fit because it's not a sd slot, but an mini sd slot.Hello guys the sd card slot fit pc 2 is too small. why is that the sd card does not fit into the fit pc 2 slot? I try to keep forcing it.
Standard height 2,5" sata SSD will fit in nicely. You don't get the highest possible performance because fitPC2 uses a SATA-PATA bridge. Whether or not you should use an SSD or HDD depends on your personal use case.I also bought a SSD 30gb sata II 2.5", but realised that not many computers take it as it is quite new technology, so therefore will I not get all the speed out if it? What do you think I should do, get a new hard drive that's slower but with more space for the same price or keep this one?
