Headless operation under Windows 7
How can I run headless under Windows 7? The GMA500 driver doesn't work and IEGD is not available for Win 7.
Re: Headless operation under Windows 7
Try uninstalling the display driver.
The default VESA driver should boot headless.
Yes but only with a very low screen resolution which is no good.irads wrote:Try uninstalling the display driver.
.. what's the problem when you are running headless anyway? Connection to terminal server (or vnc or what you want to use...) should not be limited by this.Yes but only with a very low screen resolution which is no good.
When working with Win7 headless, remote desktop is independent of local resolution so you should be able to work without the GMA500 driver.
