SBC dimension details
hscorpio
Post by hscorpio »
Following puiu's post, I'm looking for more detailed dimensions of the SBC-FITPC2 (a.k.a. the fitPC2's motherboard). I don't need any fancy CAD drawings, but I do need to know which side is 106mm and which side is 101mm. I've checked out the reference guide but there is no drawing contained in it. I've also been squinting at pictures for a while and I'd guess that the sides with the connectors are the long sides I can't be sure.
I want to send this little guy to the bottom of the sea, but I have tight housing constraints. If the long side is the one with the connectors I am out of luck :cry:
Re: SBC dimension details
The HDD sits sideways and is 100mm by itself + SATA connector. So yes, the I/O connectors are spread along the 106mm side.
hscorpio
Post by hscorpio »
Bummer... For me. This is one of the best, IMO, Atom based SBCs available right now.
Thanks for the reply.
Return to “fit-PC2 hardware”
