SSD and memory for the intense PC pro
Re: SSD and memory for the intense PC pro
Hugoalo wrote:Dear Gabriel:
I am waiting for a Intense-PC Value (Intel Celeron 847E).
- Do you know if DDR3-1600 Mhz SO-DIMM is supported in the Value model?
- Will this memory, configured at 1333 Mhz, with a lower latency (CL7) be better than other DDR3-1333 Mhz SO-DIMM with higher latency (CL9)?
The reason of those "tricky" questions is because there is not DDR3-1333 Mhz SO-DIMM with low latency (CL7) in the market, which is supposed to be beneficial in terms of speed.
Thanks in advance.
Good Day
847E model supports only 1066/1333 MHz RAM memory. Sorry.
Return to “Memory”
