I wish to detect (electrically) when a FitPC3 has completed it's power down sequence, that is (in Windows) when one selects "Shutdown".
As the USB power remains on I can't use this and I have tried using the Serial port e.g. RTS voltage, but it remain "Low" after shutdown from Windows.
Is there a test point somewhere on the one of the boards I can use?
If I could piggy-back off the front LED that would be good.
I will be using a photo MOS relay (SY4090) to do the detection.
Thank you,
John Keogh
Detecting Power Off
Re: Detecting Power Off
SLP_S3# is the signal indicating entering S3 (sleep) state in fit-PC3, where most of system functionality disabled.
It can be sampled on Extension connector P10 pin B43. See file attached.
- fit-PC3_P10.B43_SLP_S3n.PNG (31.1 KiB) Viewed 12240 times
