FitPC2i ethernet driver crashing OS
manmeet
Post by manmeet »
I recently purchased 5 FitPC2i's (D1G-C1600-W with 32GB ssd)
I installed Windows7 on it and downloaded the FitPC2i drivers. As soon as I install the the ethernet driver, the device crashes and on restarting it says "Operating System not found'.
Is there something wrong with the driver I am using.
I am using the fit-PC2i_Win7_Ethrtnet_2013.08.06 driver.
Re: FitPC2i ethernet driver crashing OS
Do you get the same behavior on all 5 units?
manmeet
Post by manmeet »
Yes I tried it on two of them with same problem.
However when trying it with a 250GB ssd, and a 1Tb diskdrive, did not give this problem.
Is there a limitation that I am unaware of? Or is this a bug?
manmeet
Post by manmeet »
I tried a different company 32gb ssd and that worked for me.
Got you. No there are no limitations whatsoever.
Please send the SN of this 5 units and I will check the revision and batch of these computers for issues.
You can use the mail address for further communication:
support@fit-pc.com
