Please update me upon results
Can't wake from sleep on FitPC2 Windows 7 Pro
Re: Can't wake from sleep on FitPC2 Windows 7 Pro
I've just tried the XP drivers following the instructions given but has not resolved the issue.
The XP IEGD drivers do work on windows 7 with the instructions given (over PM), we have installed the drivers on a number of win7 units to enable us to manually set resolution on windows 7.
Are you using a Fit-VGA converter between the PC and VGA monitor? And have you set the PC output to the required resolution for your monitor?
I'm having the same problem with my new Fit-pc2.
May I have the instructions for downloading the new driver? (I know the PW, but I miss the user name )
I accept also instructions for using the XP IEGD drivers with Win 7...
Well, FYI I tested both IEGD solutions with my headless Fit-PC2.
The Win7 drivers are faster (I noticed a better screen refresh on the VNC client monitor), but, without a monitor connected, after a reboot I have a 0x0 pixel display...
Maybe I'm missing something - I hope - but I cannot work headless with these drivers.
I had better luck with the XP drivers: with the instructions I got from Benjamin, I was able to install the XP driver on Win7 and this way I may choose any screen resolution.
Thanks again.
Thanks again.
Please write the driver download link with username and password.
My fit-pc2 (2ghz, 2gb) not work the wake up function (win 7 enterprise). I have middle in the fitpc hdmi cable and the monitor a dvi cable.
Please help, how to solve this problem? thank you
I am not able to wake up the fitpc2i either once it is in sleep mode with out hitting the power button. I did not find any way to change the wake method via the bios. Did I miss something? Is there anyway to change set this in the bios?
I have change the "power" profile in windows 7 and disabled the sleep/hibernate mode so unit does not go to sleep. This allow me to use the unit but not the power options like sleep or hibernate.
Same problem here. Windows 7 unable to wake up from sleep.
Hoping for a fix.
Cheers
Alain
Hoping for a fix.
Cheers
Alain
Please try the latest video driver
